10,000 Pa
HyperForce™ Suction
10,000 Pa
HyperForce™ Suction
Roborock Q7 TF+
Roborock Q7 TF
Dual Anti-Tangle System
Three Levels of
Water Flow
PreciSense LiDAR
Navigation
Self-Emptying Dock
Flexible App Control
Impressive HyperForce™
Suction Power
Root Out Hair
From Crevices and Carpets
Roborock Q7 TF+
HyperForce™ Suction Power 1
Roborock Q7 TF
Equipped with a JawScrapers™ Comb anti-tangle main brush and an anti-tangle side brush, this advanced system ensures smoother operation and reduced maintenance.
JawScrapers™ Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
Consistent Water
Flow Mopping
3 Levels
Water Flow Options
Detachable Mop Design
For Versatile Cleaning Needs
Anti Scale Design
Built-in nonhazardous3 descalers bag prevent scale formation and protect pipes from clogging for up to 3 years4.
Roborock Q7 TF
Roborock Q7 TF+
Roborock Q7 TF
Roborock Q7 TF+
Experience hassle-free cleaning convenience with the RockDock Plus. The large dust bag lets you clean for up to 7-9 weeks without emptying5, making it ideal for families with pets and reducing allergens.6
Temporary Cleaning
Auto Boost on Carpet
High-Intensity Mopping
Cleans Along Floor Direction
Robot Vacuum
Robot Vacuum
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN25I41V 001. The pet hair tangle rate is 0%, while short human hair (20 cm) tangle rate is 0.063%. Actual results may vary depending on usage conditions.
