Start Black Friday
Maximize Efficiency,
Master Every Clean.
Advanced Hygiene and Self-Maintenance for Lasting Performance
Enhanced for Comfort, Engineered for Convenience
Roborock H60 Series
Bend to Reach, Power to Clean
Experience a smarter way to clean with the Roborock H60 Series. Designed for effortless deep cleaning, it features a flexible wand to reach tricky spots, powerful suction to tackle dirt with ease, and a long-lasting battery for uninterrupted cleaning. The green light illumination uncovers hidden dust for a more thorough clean, while the advanced filtration system helps keep your home's air fresh by reducing secondary pollution.
0 0
Product Comparison
Roborock H60 Ultra
Buy Now
Roborock H60
Buy Now
Max Suction Power
210AW
115AW
Max Battery Life
90 min
60 min
Green Light Illumination
Screen Type
LED
Indicator
Wand Type
Bendable
Bendable
Dock Bin Capacity
500ml
500ml
Accessories
Anti-tangle brush for floors and carpets x1 Motorized mini-brush x1 2-in-1 crevice tool x1
Anti-tangle brush for floors and carpets x1 2-in-1 crevice tool x1
Roborock H60 Ultra
Roborock H60
Buy Now
Buy Now
Max Suction Power
210AW
115AW
Max Battery Life
90 min
60 min
Screen Type
LED
Indicator
Wand Type
Bendable
Bendable
Dock Bin Capacity
500ml
500ml
Accessories
Roborock H60 Ultra
Roborock H60
Roborock H60 Ultra
Roborock H60
Up to 210AW Suction
Up to 115AW Suction
Unleash True Suction Power
Powered by a powerful 210AW maximum suction, the Roborock H60 Ultra swiftly removes dirt, dust, and debris from carpets and hard floors. TÜV Rheinland-certified¹, its performance delivers a deep, meticulous clean every time.
Powered by a powerful 115AW maximum suction, the Roborock H60 swiftly removes dirt, dust, and debris from carpets and hard floors. TÜV Rheinland-certified¹², its performance delivers a deep, meticulous clean every time.
Up to
210 AW¹
115 AW¹²
Whole-Machine Suction Power
Keep Going, Keep Cleaning
Enjoy uninterrupted cleaning with up to 90 minutes of runtime on a single charge. Need more time? The detachable battery lets you swap in a fresh one for extended cleaning sessions.
Enjoy uninterrupted cleaning with up to 60 minutes of runtime on a single charge. Need more time? The detachable battery lets you swap in a fresh one for extended cleaning sessions.
*Extra battery sold separately.
Up to
90 -Min³
60 -Min¹³
Battery Life
Equipped with a lightweight pouch battery, the vacuum lasts 3x longer than the cylindrical batteries used in previous models⁴, offering easier handling and extended performance.
3x
Flexible and Bendable Wand
Bend, Flex, Clean
The flexible wand bends up to 90°, effortlessly gliding under furniture to clean tight spaces as narrow as 5.6cm, ensuring a thorough and hassle-free clean.
Down to
5.6 cm⁵
Low Reach
0°
Anti-Tangle Brush for Floors and Carpets
Flawless Cleaning Across Surfaces
JawScrapers Hybrid Brush
The curved shark-tooth design and the integrated fiber-rubber roller work together to capture, guide, and separate hair during cleaning—minimizing tangles and making maintenance easier.
0%⁶ 0%¹⁴
Tangle Rate
Effortless Floor & Carpet Cleaning
A perfect combination of rubber strips and soft fibers works wonders on both carpets and hard floors. The rubber strips shake loose embedded dirt with 7,200 beats per minute, while the soft fibers sweep up fine dust and debris.
7200 beats/min⁷
Patting frequency
Illuminate Dust, Elevate Cleaning
A precision-engineered green light with a 140° wide-angle uncovers hidden dust and fine particles, ensuring a more thorough and effortless clean.
5-Stage Filtration System
Beyond Clean, Breathe Clean
The Roborock H60 Series features a 5-stage filtration system that captures up to 99.95% of microdust particles as small as 0.3 microns, releasing cleaner air into your home.
Up to
99.95%⁸
99.95%¹⁵
retention of microdust particles
Cyclone Filtration
Metal Mesh
Multi-Cyclone Component
Sponge Filter
5
H13 HEPA Filter
Allergy-Friendly
Cleaning You Can Trust
Engineered to support a healthier home environment, our advanced filtration and cleaning system is tested and certified to effectively remove common allergens from floors and indoor air*—delivering measurable relief.
*Tested by SGS. Results show >99.9% removal efficiency for pollen (floors only) and >99.9% removal and filtration efficiency for cat and dog dander. Actual results may vary depending on usage conditions.
9-Cyclone Dust Separation System
Ensures Continuous Power
The advanced 9-cyclone system efficiently separates dust and debris, minimizing filter clogging and ensuring powerful, consistent suction every time.⁹
The advanced 9-cyclone system efficiently separates dust and debris, minimizing filter clogging and ensuring powerful, consistent suction every time.¹⁶
The spiral metal mesh filter in the dust bin channels hair and dust into the bin smoothly, reducing tangles in the mesh and maintaining steady suction for efficient cleaning.
Multiple Tools and Accessories
Motorized Mini-brush
The motorized mini-brush removes dust and pet hair from sofas, beds, and fabrics with zero hair tangling.
6000 times/minute¹⁰
Patting frequency to remove dust mite*
0%⁶
Tangle Rate
*Tested by SGS under Test Method PT‑23‑000‑401951. Shown to remove over 99.99% of dust mites using the motorized mini-brush. Actual results may vary depending on usage conditions.
2-in-1 Crevice Brush
The 2-in-1 crevice brush helps clean tight spaces and delicate surfaces with ease.
LED Screen
Easily view battery status and choose from three cleaning modes.
Washable Dustbin and HEPA Filters
The washable dustbin and filters make cleaning easy and help keep the vacuum running efficiently over time.¹¹
The washable dustbin and filters make cleaning easy and help keep the vacuum running efficiently over time.¹⁷
Roborock H60 Ultra
Roborock H60
Vacuum
293*250*1162mm
293*250*1162mm
STAY TUNED IN!
1. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN253JHD001.
2. For use within a home environment only. Actual results may vary depending on usage conditions.
3. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
4. Refers to Roborock's previous cordless stick vacuum cleaner models. Results are based on Roborock internal testing. Actual results may vary depending on usage conditions.
5. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
6. Certified NO.PT/25/GEN/0112 by SGS. Actual results may vary according to the home environment.
8. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN253JHD001.
9. Certified NO.PT/25/GEN/0111 by SGS. Actual results may vary according to the home environment.
10. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
11. Actual results may vary depending on usage conditions.
12. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN25LG2F001.
13. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
14. Certified NO.PT/25/GEN/0216/1 by SGS. Actual results may vary according to the home environment.
15. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN25LG2F001.
16. Certified NO.PT/25/GEN/0215 by SGS. Actual results may vary according to the home environment.
17. Actual results may vary depending on usage conditions.
