Start Black Friday
Efficiency Elevated,
Cleaning Perfected.
Advanced Hygiene and Self-Maintenance for Lasting Performance
Enhanced for Comfort, Engineered for Convenience
Roborock H60 Hub Ultra
Cleaning? Just Hand It Over
Cleaning isn’t truly finished until every trace of dust is gone—until now. With automatic dust evacuation and charging, our all-in-one auto-empty dock handles the hidden cleanup for you. Paired with powerful suction, long battery life, an anti-tangle brush, and a multi-filtration system, the Roborock H60 Hub Series delivers effortless, efficient, and truly hygienic cleaning.
0 0
Product Comparison
Buy Now
Max Suction Power
210AW
Max Battery Life
90 min
Green Light Illumination
Screen Type
LED
Wand Type
Telescopic
Auto-Empty Dock
Auto-Dust Evacuation
Auto Charging
Dock Internal Storage
Dock Dust Bag Capacity
3L
Accessories
Anti-tangle brush for floors and carpets x1 Motorized mini-brush x1 2-in-1 crevice brush x1
Buy Now
Max Suction Power
210AW
Max Battery Life
90 min
Screen Type
LED
Wand Type
Telescopic
Auto-Empty Dock
Auto Charging
3L
Accessories
Totally Hands-Free,
Hygienic Emptying and Charging for Your Convenience
All-in-One
Auto-Empty Dock
Dock it and enjoy debris-free cleaning with automatic dust evacuation. In just 10 seconds³, dust is sealed into a 3L large-capacity dust bag, and your vacuum is recharged, ready for the next clean.
All-in-One
Auto-Empty Dock
Ergonomic Docking Height
Designed at an optimal height of 848mm, the dock allows seamless vacuum placement without high lifting—simply retract the telescopic wand and dock it with ease.
848 mm
Height of The Dock
Dock it
Large-Capacity
3L
Dust Bag
Up to
100 Days⁴
Maintenance-Free
Breathe Easy with a Hygienic Cleaning Solution
Sealed Dust Bag with
99%
Bacterial Removal Rate⁵
The fully-sealed dust bag and HEPA filtration trap fine dust and allergens, keeping them securely contained and out of your living space.
Internal Storage for Multiple Cleaner Heads
The dock features a convenient storage to neatly store your anti-tangle brush for floors and carpets, a motorized mini-brush, and a 2-in-1 crevice tool.
Powerful 210AW Max Suction
True Power, Truly Clean
With an impressive 210AW max suction power, the Roborock H60 Hub Ultra easily lifts dirt, dust, and debris from both carpets and hard floors. Certified by TÜV Rheinland¹, its strong performance guarantees a deep, thorough clean every time.
Up to
210 AW¹
Whole-Machine Suction Power
Cleaning That Endures
Keep cleaning without interruptions. Enjoy up to 90 minutes of runtime on a single charge.
Up to
90 -Min⁶
Battery Life
Equipped with a lightweight pouch battery, the vacuum lasts 3x longer than the cylindrical batteries used in previous models⁷, offering easier handling and extended performance.
3x
Anti-Tangle Brush for Floors and Carpets
Flawless Cleaning Across Surfaces
JawScrapers™ Hybrid Brush
The curved shark-tooth design and the integrated fiber-rubber roller work together to capture, guide, and separate hair during cleaning—minimizing tangles and making maintenance easier.
0%⁸
Tangle Rate
Effortless Floor & Carpet Cleaning
A perfect combination of rubber strips and soft fibers works wonders on both carpets and hard floors. The rubber strips shake loose embedded dirt with 7,200 beats per minute, while the soft fibers sweep up fine dust and debris.
7200 beats/min⁹
Patting Frequency
See the Unseen, Clean with Ease
A powerful green light exposes invisible dust and fine particles, while its 140° central alignment ensures maximum floor coverage for a deeper clean.
5-Stage Filtration System
Clean Air, Everywhere
The Roborock H60 Hub Series features a 5-stage filtration system that captures up to 99.95% of microdust particles as small as 0.3 microns, releasing cleaner air into your home.
Up to
99.95%¹⁰
Retention of Microdust Particles
Cyclone Filtration
Metal Mesh
Multi-Cyclone Component
Sponge Filter
5
HEPA Filter
Allergy-Friendly
Cleaning You Can Trust
Engineered to support a healthier home environment, our advanced filtration and cleaning system is tested and certified to effectively remove common allergens from floors and indoor air*—delivering measurable relief.
*Tested by SGS. Results show >99.9% removal efficiency for pollen (floors only) and >99.9% removal and filtration efficiency for cat and dog dander. Actual results may vary depending on usage conditions.
9-Cyclone Dust Separation System
Less Clogging, Unstoppable Power
The advanced 9-cyclone system efficiently separates dust and debris, reducing filter clogging and maintaining powerful, consistent suction. ¹¹
The spiral metal mesh filter in the dust bin channels hair and dust into the bin smoothly, reducing tangles in the mesh and maintaining steady suction for efficient cleaning.
Multiple Tools and Accessories
Motorized Mini-brush
The motorized mini-brush removes dust and pet hair from sofas, beds, and fabrics with zero hair tangling.
6000 times/minute¹²
Patting frequency to remove dust mite*
0%⁸
Tangle Rate
*Tested by SGS under Test Method PT‑23‑000‑401951. Shown to remove over 99.99% of dust mites using the motorized mini-brush. Actual results may vary depending on usage conditions.
2-in-1 Crevice Brush
The 2-in-1 Crevice brush helps clean tight spaces and delicate surfaces with ease.
LED Screen
Easily view battery status and choose from three cleaning modes.
Adjustable Length
Two adjustable lengths for greater reach and comfort. Just hold the middle of the telescopic wand to easily adjust the height—no buttons needed.
Washable Dustbin and HEPA Filters
The washable dustbin and filters ensure hassle-free cleaning and long-term efficiency.¹³
ROBOROCK H60 Hub Ultra
Auto-Empty Dock
289*289*848mm
Vacuum
293*250*1146mm
STAY TUNED IN!
1. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN253JHD001.
2. For use within a home environment only. Actual results may vary depending on usage conditions.
4. Based on internal testing carried out by the manufacturer. Actual emptying intervals may vary depending on cleanliness conditions.
5. Based on testing carried out by SGS. Effectively removes 99% of Staphylococcus aureus and Escherichia coli. Test report number: SHFT250200007571, SHFT250200007471. Actual results may vary depending on usage conditions.
6. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
7. Refers to Roborock's previous cordless stick vacuum cleaner models. Results are based on Roborock internal testing. Actual results may vary depending on usage conditions.
8. Certified NO.PT/25/GEN/0112 by SGS. Actual results may vary according to the home environment.
9. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
10. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN253JHD001.
11. Certified NO.PT/25/GEN/0111 by SGS. Actual results may vary according to the home environment.
12. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
13. Actual results may vary depending on usage conditions.
14. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN25D3NM001.
15. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
16. Certified NO.PT/25/GEN/0190 by SGS. Actual results may vary according to the home environment.
17. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN25D3NM001.
18. Certified NO.PT/25/GEN/0194 by SGS. Actual results may vary according to the home environment.
19. Actual results may vary depending on usage conditions.
20. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
21. Based on internal testing carried out by the manufacturer. Actual emptying intervals may vary depending on cleanliness conditions.
22. Based on testing carried out by SGS. Effectively removes 99% of Staphylococcus aureus and Escherichia coli. Test report number: SHFT250400016571, SHFT250400016572. Actual results may vary depending on usage conditions.
23. Tested by TÜV Rheinland based on the IEC 62885-4:2020/5.8 standard. Tested without any accessories, in MAX mode with a full battery, and using testing equipment with a diameter of 10 mm. Actual results may vary depending on usage conditions. Test report number: CN25LG2F001.
24. Based on Roborock internal testing with a fully charged battery in ECO mode using the 2-in-1 crevice brush. Actual runtime may vary under specific conditions or when using different accessories.
25. Certified NO.PT/25/GEN/0216/1 by SGS. Actual results may vary according to the home environment.
26. Tested by TÜV Rheinland based on ASTM F1977-22 standard. Tested in MAX mode for capturing particles of 0.3~5 μm diameter. Actual results may vary depending on usage conditions. 5-stage filtration system includes cyclone filtration, a metal mesh, a multi-cyclone component, a sponge filter, and a HEPA filter. Test report number: CN25LG2F001.
27. Certified NO.PT/25/GEN/0215 by SGS. Actual results may vary according to the home environment.
28. Actual results may vary depending on usage conditions.
